1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Advice sought on fanning data to several PVs
To: [email protected]
Date: Thu, 21 May 1998 17:27:15 -0700 (PDT)
We use GPIB to access a DVM whose voltage translates into PEP-II total Ring current. Up to now we
have used only one number, along with the Epics timestamp from the associated PV. We have provided
adequate device support to access the single number of interest.
This DVM is now to be multiplexed for two rings, delivering four doubles on each read: Beam
Current, Time of reading (ms since some arbitrary 0), Other Beam current, Other time of reading.
We can fetch this data with modified device support (into an internal ascii buffer), but now must
decide how to get it into four seperate data.
Scenario 1:
Modify the device support for a Waveform (length 4, doubles). Let a subroutine record fan these 4
items to a seq record, which strobes them into 4 individual soft AI records.
Question: is this overly expensive (at 1 Hz readout)?
Scenario 2:
Have one GPIB-AI record which does the above processing in device support.
Question: Which links can this "master" AI record follow to force updates of the other three?
          What do the Database connections look like?
Scenario 3:
Have one GPIB-AI record which cycles through the 4 values each time the record is processed.
Question: How does one synchronize this kludge?
Thanks in advance for your advice.
/Ron Chestnut
SLAC
Prev: vme Record Jeffrey Mcdonald
Next: OMS steppermotor problem Albert Grippo
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Advice sought on fanning data to several PVs Tim Mooney
