1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: OMS steppermotor problem
To: [email protected]
Date: Fri, 22 May 1998 11:55:58 EDT
  At Jefferson Lab there are several MVME 167/177 IOCs with OMS VME44
stepper motor control cards. When they are combined with an MVME 162
card running HiDEOS in the same crate, we have been experiencing ioc
crashes.  These may occur after several motor moves, or they may never
occur, depending on the particular combination of software applications,
OMS card and stepper motor chassis, the latter being used to supply
power to the motor and to microstep.  When the ioc crashes, it locks
up immediately after a step is given, and there is no way to log on to
determine the problem.
  A great deal of time has been spent trying to debug this annoying
problem.  The following is a summary of findings:
	1. The problem did not occur on a test ioc when there were
	no other applications present. However, when an IP Digital48
	I/O card was added along with an application which used scan
	tasks on this card, we got consistent crashes (no crashes when
	the scans were changed to passive).  We had been using the epics
	steppermotor record, but for debug purposes switched to a very
	short subroutine record which talked directly to the OMS card.
	This appeared to very consistently eliminate the problem, so
	we thought there was a bug in the steppermotor record.
	2. When we moved the working applications to an operational ioc,
	the problem resurrected, even with the simple direct OMS card
	addressing subroutine. It occurred with or without the
	steppermotors connected to the chassis, which ruled out the
	motor itself.  In contrast, similar setups on 2 nearby operational
	iocs, using epics steppermotor records, along with Digital48
	scan task applications work extremely reliably. When questioned,
	the developer of these systems said she spent many weeks working
	with the hardware people to find the right combination of chassis
	and OMS cards that worked.
	3. Further testing of the non-reliable system on the operational
	ioc showed that the system could be made to work fairly reliably
	by setting ECHO OFF.  The default option is ECHO ON and this is
	set in the steppermotor record.  When it was set OFF in the
	subroutine record version, 4 of the 5 motors appeared to work
	reliably, and have been so operating for several months.  Setting
	ECHO OFF appears to reduce bus traffic and hence the probability
	of conflict with HiDEOS tasks and/or the fair amount of noise
	which was present on the bus.  However, the fifth motor continued
	to cause crashes after a random number(generally 1- 20) of steps
	were given.  This problem was greatly and consistently reduced
	by removing an application on the ioc which used GPIB 1 second scan
	tasks.  Removing another GPIB application on the ioc with only
	passive scans made no difference. The system is now running with
	only the Digital48 and passive GPIB tasks, but still crashes on
	occasion, after perhaps several hundred steps.  We are int he process
	of removing all HiDEOS tasks from this ioc.
	4. Another system, developed independently by a third person at
	the lab, and using the epics steppermotor record, also experienced
	periodic crashes when running on an operational ioc with other
	applications, several of which used HiDEOS.  When this system was
	moved to a spare ioc with no other applications, the crashes ceased.
 Has anyone else experienced such problems with the OMS VM44 ?
    Al Grippo
    Jefferson Laboratory
    Newport News, VA
    757-269-5015
Prev: Advice sought on fanning data to several PVs Ron Chestnut
Next: RE: OMS steppermotor problem Mark Rivers
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Advice sought on fanning data to several PVs Tim Mooney
