1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Process-Valve icon color
From: Matthias Clausen DESY -MKS-2/KRYK- <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Fri, 5 Jun 1998 17:35:58 +0200 (MET-DST)
>> 2)  What color convention are you using ?
>As BESSY is an accelerator facility, the  that are monitored separate
>different sections of the vacuum chamber. Closed valves block the beam, so
>they are displayed red.
In process controls the red valves indicates closed and green open. You might want to use
(and argue about) another color for the state inbetween (analog valves) - we use blue -.
Matthias
Prev: BITBUS availability... Udo BOTHNER
Next: Re: BITBUS availability... Ned Arnold
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Process-Valve icon color Ralph Lange
Next: Re: Process-Valve icon color Bill McDowell
