I have started testing the portable channel access server on linux.
Red Hat Linux 5.0 (patches are current)
Epics 3.13 beta 11
program 1: CAS with 500 pv's
program 2: simulated I/O scanner with approx 1000 puts per second
program 3: medm
One display: 3 bar monitors, 6 text monitors, 1 meter
program 4: Dummy event receiver
500 events added
event handler: (procedure is ridiculous; objective is to produce activity)
static int count = 0;
count++
remove buffer from free queue
copy count to buffer
insert buffer into active queue
if there is only one node on active queue then signal event thread
event thread:
lock thread preemption
get chid for "num_events" as id
unlock thread preemption
while ( 1 ) {
while ( active queue is not empty ) {
remove buffer from active queue
value = count field of buffer
ca_put( DBR_LONG, id, &value );
insert buffer into free queue
wait for signal
main thread:
get all chids and add events
create event thread
while ( 1 ) {
ca_pend_io( 5.0 );
ca_pend_event( 0.001 );
delay 100 ms
Everything has gone well for about 72 hours except for Medm. Medm runs
fine and then, at some (apparently) random time, begins consuming virtual
memory at a rate of about 1K bytes per second until all is consumed. There
is no noticeable change in behavior or performance when Medm gets into this
state (until the system starts swapping).
I realize that the problem could be in the linux kernel, X libs, or C libs. I
will try to build the test on another platform. Any comments/suggestions
are appreciated.
John Sinclair
[email protected]
Oak Ridge National Lab
423-576-6362 423-574-1268 (fax)
Color rules john sinclair
Marty Kraimers UC Distinguished Performance Award Bill McDowell
<1998>
2025
2026
Re: Portable channel access server on linux Garrett D. Rinehart
<1998>
2025
2026
