1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Portable channel access server on linux
To: [email protected], [email protected]
Date: Mon, 8 Jun 1998 15:39:13 -0500
> Everything has gone well for about 72 hours except for Medm. Medm runs
> fine and then, at some (apparently) random time, begins consuming virtual
> memory at a rate of about 1K bytes per second until all is consumed. There
> is no noticeable change in behavior or performance when Medm gets into this
> state (until the system starts swapping).
> I realize that the problem could be in the linux kernel, X libs, or C libs. I
> will try to build the test on another platform. Any comments/suggestions
> are appreciated.
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 423-576-6362   423-574-1268 (fax)
John,
If you (or anyone else) find out what the problem with MEDM is, PLEASE let me
know. I'm still trying to track down the problem with mine (RH Linux 4.1, MEDM
2.3.3). I went so far as to set up identical machines and run them tandomly.
The original one does as always (medm dies every 6-7 hours), but a cron task I
set up restarts it. Medm on the "new" one never leaves the process list, but
it's quite dead nonetheless. Unfortunately, my cron task can't tell since it
finds medm in the process list, so I don't know how regularly this (would)
happen. In both cases, Linux and X continue unaffected.
-- Garrett Rinehart
   Intense Pulsed Neutron Source
   Argonne National Laboratory
Prev: Marty Kraimers UC Distinguished Performance Award Bill McDowell
Next: CVS question jin yu
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Portable channel access server on linux john sinclair
Next: RE: Portable channel access server on linux Jeff Hill
