1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Portable channel access server on linux
To: "'john sinclair'" <[email protected]>, tech talk <[email protected]>
Date: Wed, 10 Jun 1998 09:19:14 -0600
> Everything has gone well for about 72 hours except for Medm. Medm runs
> fine and then, at some (apparently) random time, begins consuming virtual
> memory at a rate of about 1K bytes per second until all is consumed. There
> is no noticeable change in behavior or performance when Medm gets into this
> state (until the system starts swapping).
> I realize that the problem could be in the linux kernel, X libs, or C libs. I
> will try to build the test on another platform. Any comments/suggestions
> are appreciated.
I remember reading that X programs that continuously call XLib, but do not call XNextEvent()
will continue to allocate memory for each incoming X event until the process runs out of virtual
memory.
Perhaps medm is stuck somewhere where it is calling XLib, but it isn't processing
incoming XEvents. If the CA client lib was sufficiently busy perhaps it is calling
monitor callbacks in medm from ca_pend_event() and some of these callbacks are
making XLib calls, but none of these calls directly or indirectly call XNextEvent()?
Jeff
Prev: request for PMAC records Kevin Tsubota
Next: RE: help on epics base 3.13beta11 installation Jeff Hill
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Portable channel access server on linux Garrett D. Rinehart
Next: Marty Kraimers UC Distinguished Performance Award Bill McDowell
