Hi Maren,
The first question to ask when the dm screens won't connect is:
Is the net mask on your ioc set to the same as the
netmask on your sun?
In the boot parameters the line
inet on ethernet (e) : 128.165.32.88:ffffff00
Should look something like the above.
The ffffff00 after the : tell
the ioc to accept broadcasts from inet addresses in the 128.165.32....
subnet.
Of course there are lots of other possible problems:
(a run away sequence at higher priority than channel access will
do it), but I would look at the netmask first.
Good Luck,
Rozelle
|Rozelle Wright Phone (505) 667-4804 |
|Los Alamos Natl Labs LANSCE-8 FAX (505) 665-5107 |
|PO Box 1663 MS-H820 Group Office (505) 667-6087|
|Los Alamos, NM 87545 email : [email protected] |
> From [email protected] Wed Jun 17 12:50 MDT 1998
> Sender: [email protected]
> Date: Wed, 17 Jun 1998 08:49:50 -1000
> Organization: Joint Astronomy Centre, Hilo, HI
> X-Mailer: Mozilla 3.01Gold (X11; I; SunOS 5.5 sun4m)
> Mime-Version: 1.0
> To: [email protected]
> Subject: boot problems & related on hkbaja47
> Content-Transfer-Encoding: 7bit
> X-Lines: 32
> Hi all,
> after spending a day on it yesterday I guess it is time to ask:
> After having changed architecture from hkbaja60 to hkbaja47
> and IOC (crate) I ran into the following problems:
> - the hkbaja47 is only able to boot (load vxWorks) with one user id.
> I can't find any protection problems. It is not dependent on the host it
> boots from (at least).
> - after getting it to boot, I find that, while everything in the
> startup file appears to get executed ok, and checking with dbpr that
> the records actually process, my dm screen tells me that all the
> channels are disconnected. caRepeater is running, I took all access
> restrictions out of the resource.def file (and actually switched to
> doing the iocInit without file specification)
> - when I run Crosswind it still believes that I have the old hkbaja60
> architecture and says it can't read the files.
> System details:
> Epics 3.13 beta 11, Tornado 1.0.1 (hkbaja47),
> Solaris 2.6 (sparc 20 clone)
> I don't really need to run Crosswind, I just tried to run it to
> possible help me find what the rest of the problems are but instead
> found that there was problems with it too.
> Does anybody have any ideas what I'm overlooking?
> Thanks in advance,
> Maren Purves
> UKIRT
- Re: boot problems & related on hkbaja47 Maren Purves
<1998>
2025
2026
<1998>
2025
2026
