1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: boot problems & related on hkbaja47
To: [email protected]
Date: Wed, 17 Jun 1998 09:41:14 -1000
Rozelle Wright wrote:
> Hi Maren,
> The first question to ask when the dm screens won't connect is:
> Is the net mask on your ioc set to the same as the
> netmask on your sun?
> Of course there are lots of other possible problems:
> (a run away sequence at higher priority than channel access will
> do it), but I would look at the netmask first.
Hi Rozelle, Deb, and everybody:
I knew I forgot something in my original message. Here are my boot
parameters:
boot device             :  dec
processor number        :  0
host name               :  lilikoi
file name               :
/local/vxworks/tornado-1.0.1/target/config/hkbaja47/vxWorks
inet on ethernet (e)    :  128.171.90.153:ffffff00
inet on backplane (b)   :
host inet (h)           :  128.171.90.227
gateway inet (g)        :
user (u)                :  npr
ftp password (pw) (blank = use rsh)     :
flags (f)               :  0x8
target name (tn)        :  bill
startup script (s)      :
/home/maren/ukroot/ufti_0p0/bin/hkbaja47/start_ufti_sim
other (o)               :
the same boot parameters (different architecture, IP address of crate
and name of crate) worked with the hkbaja60 (note also that I booted
that one as me rather than having to use Nick's user id).
So, I think the net mask is ok.
Deb Kerstiens wrote:
>I don't know much about the hkbaxxxx, so I probably can't help much
>there.
>However, we do have similar problems with our PC IOCs when we boot them
>from the PC hard disk.  We have added "loginUserAdd" lines to our
>startup
we pipe in our password file ...
so, to complete things, this is the startup file:
console_device = open( "/vio/0", 2, 0 )
ioGlobalStdSet( 1, console_device )
ioGlobalStdSet( 2, console_device )
hostAdd(  "malama", "128.171.90.203" )
nfsAuthUnixSet("malama", 60001, 60001, 0, 0 )
nfsAuthUnixSet("lilikoi", 60001, 60001, 0, 0 )
nfsMount( "malama", "/local",    "/local" )
nfsMount( "lilikoi", "/export/home/maren", "/home/maren" )
nfsMount( "lilikoi", "/export/home/maren/ukroot", "/ukirtdata" )
 < /local/vxworks/etc/passwd
tyBackspaceSet 0177
cd "/home/maren/ukroot/ufti_0p0"
pwd
ld < epics/base/bin/hkbaja47/iocCore
ld < epics/base/bin/hkbaja47/epicsSupport
dbLoadDatabase "epics/base/dbd/epicsSupport.dbd"
ld < ./bin/hkbaja47/lcudrv
ld < ./bin/hkbaja47/b016
ld < ./bin/hkbaja47/imgLib
ld < ./bin/hkbaja47/piIoLib
ld < ./bin/hkbaja47/inmos
ld < ./bin/hkbaja47/s5933Lib
ld < ./bin/hkbaja47/41csc
ld < ./bin/hkbaja47/41sim
ld < ./bin/hkbaja47/acamLib
ld < ./bin/hkbaja47/fitsio
ld < ./bin/hkbaja47/dhsLib
ptyDevCreate( "/pty/41sim.", 0x1000, 0x1000 )
sp cs41Sim_camera_server, "/pty/41sim.S"
acamDrv = acamDrvCreate ("ufti","./bin/trans","4100hw_sim.cfg")
cs41SimDebug=0
acamNew(  acamDrvId( "ufti" ) )
dhsInit ("ufti")
dbLoadDatabase "./dbd/acamSupport.dbd"
dbLoadDatabase "./dbd/dhsSupport.dbd"
dbLoadRecords "./data/ufti.db"
iocLogDisable=1
iocInit
All of this appears to work, just I can't debug it and it doesn't
appear on the screen - and I can't boot it as myself.
I think for the moment I'll got with Ned Arnold's suggestion of
logging out, and possibly rebooting.
Thanks all, I'll keep you posted.
Maren
Re: boot problems & related on hkbaja47 Rozelle Wright
Prev: Re: boot problems & related on hkbaja47 Rozelle Wright
Next: Xycom 566 waveform Garrett D. Rinehart
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: boot problems & related on hkbaja47 Ned Arnold
