1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: boot problems & related on hkbaja47
To: [email protected]
Date: Wed, 17 Jun 1998 14:48:08 -0500
> Hi all,
> after spending a day on it yesterday I guess it is time to ask:
> After having changed architecture from hkbaja60 to hkbaja47
> and IOC (crate) I ran into the following problems:
> - the hkbaja47 is only able to boot (load vxWorks) with one user id.
> I can't find any protection problems. It is not dependent on the host it
> boots from (at least).
> - after getting it to boot, I find that, while everything in the
> startup file appears to get executed ok, and checking with dbpr that
> the records actually process, my dm screen tells me that all the
> channels are disconnected. caRepeater is running, I took all access
> restrictions out of the resource.def file (and actually switched to
> doing the iocInit without file specification)
> - when I run Crosswind it still believes that I have the old hkbaja60
> architecture and says it can't read the files.
> Does anybody have any ideas what I'm overlooking?
> Thanks in advance,
> Maren Purves
> UKIRT
Interesting -
I had the same problem when I swapped in an MVME177 for a MVME167 !  It seems
to be a problem at the client end. The first time I had to log out/in of
my Unix workstation before connections could be re-established, the next time
that didn't work, I had to reboot my Unix workstation! It seems that
something (caRepeater ?) does not like the CPU architecture to change from
one boot of an IP number to another. I was going to send a note to Jeff, but
now he's heard it. Jeff, I can reproduce this problem if you want to look at it.
        Ned
more details - Re: boot problems & related on hkbaja47 Maren Purves
Prev: Xycom 566 waveform Garrett D. Rinehart
Next: more details - Re: boot problems & related on hkbaja47 Maren Purves
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: boot problems & related on hkbaja47 Maren Purves
