Ned Arnold wrote:
> The first time I had to log out/in of
> my Unix workstation before connections could be re-established, the next time
> that didn't work, I had to reboot my Unix workstation! It seems that
> something (caRepeater ?) does not like the CPU architecture to change from
> one boot of an IP number to another. I was going to send a note to Jeff, but
> now he's heard it. Jeff, I can reproduce this problem if you want to look at it.
Following Ned Arnold's advice I took the "I'll only want to do this
once" approach and rebooted my workstation. Unfortunately that didn't
help. Then I followed the rest of Rozelle's "Debugging EPICS ..."
paper and found:
My netmasks are ok.
The cpu is not busy.
"casr" says no clients are connected.
I can't find any of my channels with cau.
I thought I found it when I walked over to the (physical) console
and found that it said that the database initialization failed
(and below that said that the database initialization completed),
but then remembered that it always does that (no idea why).
(I also took out the changes I made to the database and that didn't
have any effect either).
Any suggestions welcome (I'm absolutely out of ideas).
Thanks again and in advance,
Maren
- Problem solved ... Re: boot problems & related on hkbaja47 Maren Purves
- Re: boot problems & related on hkbaja47 Ned Arnold
RE: boot problems & related on hkbaja47 Jeff Hill
<1998>
2025
2026
<1998>
2025
2026
