1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: boot problems & related on hkbaja47
To: "'Maren Purves'" <[email protected]>, "[email protected]" <[email protected]>
Cc: "Ned Arnold [[email protected]] (E-mail)" <[email protected]>
Date: Wed, 17 Jun 1998 16:39:30 -0600
Maren, Ned,
On Wednesday, June 17, 1998 12:50 PM, Maren Purves [SMTP:[email protected]] wrote:
> After having changed architecture from hkbaja60 to hkbaja47
> and IOC (crate) I ran into the following problems:
> - the hkbaja47 is only able to boot (load vxWorks) with one user id.
> I can't find any protection problems. It is not dependent on the host it
> boots from (at least).
> - after getting it to boot, I find that, while everything in the
> startup file appears to get executed ok, and checking with dbpr that
> the records actually process, my dm screen tells me that all the
> channels are disconnected. caRepeater is running, I took all access
> restrictions out of the resource.def file (and actually switched to
> doing the iocInit without file specification)
The ARP protocol is used to dynamically discover the physical address of
the host that has a particular IP address. Hosts use ARP only initially
when they don't know the physical address that corresponds to a particular IP
address. Subsequently, an ARP cache is consulted for all future
communication with the remote host.
When you move an IP address from one physical Ethernet address
to another you need to reinitialize the ARP cache on all hosts that
have used the old physical Ethernet address/IP address combination
in the past.
On Solaris this can be accomplished by typing "arp -d <host name>"
as superuser, or by rebooting the host.
Jeff
Prev: more details - Re: boot problems & related on hkbaja47 Maren Purves
Next: Problem solved ... Re: boot problems & related on hkbaja47 Maren Purves
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem solved ... Re: boot problems & related on hkbaja47 Maren Purves
Next: RE: boot problems & related on hkbaja47 Jeff Hill
