1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mv177
To: [email protected], [email protected]
Cc: [email protected]
Date: Thu, 25 Jun 1998 14:15:07 -0700
> > We are considering buying an "mv177" rather than "mv167"
> > for one of the systems in our project.
> > Are there any issues that I should be aware of running
> > EPICS under vxWorks 5.2 on the "mv177"?
> > Presumably we will need a new BSP. Does the same cross-compiler
> > work for both boards - i.e. could you load a "167" image on
> > the "177"?
	I accidentally did this, and it ran.  Certainly all .o's
	will work.
> We are using a few MVME177's as direct replacements. Yes you need a new BSP.
> With EPICS R3.13, just add
> CROSS_COMPILER_TARGET_ARCHS = mv167 mv177        in config/CONFIG
> and
> ARCH = mv177           in iocBoot/iocName/Makefile
> and let the Makefiles do their magic.
	Well, in R3.13beta11 at least, you need to copy CONFIG.mv167
	to CONFIG.mv177, then change "ARCH_DEP_CFLAGS = -DCPU=MC68040 ..."
	to "ARCH_DEP_CFLAGS = -DCPU=MC68060 ...
> At APS, MV177's don't seem to boot from fast solaris machines, we have to
> specify a boot host that's running sunOs. This has not been a problem at
> PPL, however, where they are running a later version of Solaris and vxWorks
> 5.3.
	Have not seen that problem with Solaris 2.5.1 and any model
	Sun.
Prev: Re: mv177 Ned Arnold
Next: Re: mv177 Frank Lenkszus
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
