1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Access Config File Host Names
To: <[email protected]>
Date: Mon, 6 Jul 1998 09:17:20 -0400
When I specify a host name which contains a dash (-),  such as psichta-pc,
the ascheck command flags this as a syntax error.  Is there a way I can use
host names which contain a dash ?
***Output from ascheck command***
Error line 19 : syntax error psichta-pc
access security: bad configuration file from asInitialize
***Lines 18 and 19 of the access configuration file are ***
HAG(cr) {epicsrv1, psichtapc}
HAG(mg_station) {ead03, psichta-pc}
-ps
Re: Access Config File Host Names Marty Kraimer
Prev: VxWork5.3 halt at starting Tatiana V. Salikova
Next: Re: Access Config File Host Names Marty Kraimer
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
