1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access Config File Host Names
To: [email protected]
Date: Mon, 06 Jul 1998 08:33:16 -0500
Paul Sichta wrote:
> When I specify a host name which contains a dash (-),  such as psichta-pc,
> the ascheck command flags this as a syntax error.  Is there a way I can use
> host names which contain a dash ?
> ***Output from ascheck command***
> Error line 19 : syntax error psichta-pc
> access security: bad configuration file from asInitialize
> ***Lines 18 and 19 of the access configuration file are ***
> HAG(cr) {epicsrv1, psichtapc}
> HAG(mg_station) {ead03, psichta-pc}
> -ps
This is fixed in beta12.
For previous releases you can modify <base>/src/as/asLib_lex.l
Change
name    [a-zA-Z0-9_\.]
to
name    [a-zA-Z0-9_\-:\.\[\]<>;]
and then
gnumake
cd ../iocCore
gnumake
Marty Kraimer
Access Config File Host Names Paul Sichta
Prev: Access Config File Host Names Paul Sichta
Next: Capfast licence manager Graham Waters
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
