1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: XVME 566 driver problem
To: Miroslaw Dach <[email protected]>
Cc: [email protected]
Date: Fri, 24 Jul 1998 06:55:29 -0600 (MDT)
The card has two memory areas - one in short address space and one in
standard adress space. There are also 3 different types supported for the
xy566:
single ended, differential, and latched. The base addresses are specified
in module_types.h for short address space as:
0x6000, 0x7000, 0xe000
for standard address space they are
0x00000, 0x40000, 0xc0000
The code producing the error is in drvXy566.c
    /* map the io card into the VRTX short address space */
    status = sysBusToLocalAdrs(VME_AM_SUP_SHORT_IO, base_addr, &pai566);
    if(status != OK){
        logMsg("%s: failed to map XY566 A16 base addr A16=%x\n",
                __FILE__,
                base_addr);
        return ERROR;
    /* map the io card into the standard address space */
    status = sysBusToLocalAdrs(VME_AM_STD_SUP_DATA,paimem, &pai566io);
    if(status != OK){
        logMsg( "%s: failed to map XY566 A24 base addr A24=%x\n",
                __FILE__,
                paimem);
        return ERROR;
Hope this helps,
	Bob
XVME 566 driver problem Miroslaw Dach
Prev: XVME 566 driver problem Miroslaw Dach
Next: Re: Power PC and EPICS Noboru Yamamoto
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Histogram Record support Mark J. Ryan
