> Dear All,
> We are considering upgrading to a Power PC based CPU board.
> I would be interested to hear of users experiences with
> EPICS on any Power PC based board.
We uses Force PowerCore 603 for development of KEKB control system.
In a few weeks, we will get Force PowerCore6750, which uses PPC-750
as a CPU.
EPICS R3.13beta11 runs on PCore603.
So far , We have tested limited number of dirvers:
drvGpib.c
Camac support and camacLib with Hytec 2992 Serial Driver
drvSerial/devSerial
Modbus+ suppport
Arcnet driver
Mr. Jun-ich Odagiri is the person who ported EPICS to Froce PPC board
in KEK. He wrote a memo on the port of EPICS to PPC in Japanse ( sorry).
Here I briefly summarize his memo. There are two categories in the
modifications. One related to the difference between compilers
for 68K and PPC. Another is CPU board specific.
1) Compiler differences.
1-1) signed or unsigned integral variables.
According to our study, the compiler for MC68K and the compiler for PPC
in VxWorks have different default types for integral variables.
char | short | int | long
68k | signed | signed | unsigned | unsigned
PPC | unsigned | unsigned | signed | signed
In some cases, this difference causes different behaviour between
two platforms. You must use "signed" or "unsigned" keywords explicitly.
For "char" type, compiler option "-fsigned-char" can be used.
1-2) "_" in the global name.
EPICS uses global symbol table(i.e. it uses symFindByName() function)
to find device/record support routines.
68K compiler adds "_" in a front of the global symbol name, however,
PPC compiler DOES NOT.
Some EPICS routines assume that the global name have "_" at the front of
symbol name. You need to fix this in the following files.
bdt/bdtServ.c
db/devLib.c
db/drvTS.c
db/iocInit.c
dbStatic/dbStaticRun.c
dbTools/PVSvx.c
dev/devAiSymb.c
dev/devAoSymb.c
dev/devLiSymb.c
dev/devLoSymb.c
dev/devSiSymb.c
dev/old/drvGpib.c ( for Hideos support)
rec/gsubRecord.c
rec/subRecord.c
drv/ansi/drvEpvxi.c
libvxWorks/ldpp.c
1-3) -mnobitfield option
A compiler option "-mnobitfield" does not exists for PPC compiler.
1-4) va_list in errPrintfVX.c.
In 68K compiler, va_list is "typedef"-ed as pointer type, while PPC
compiler "typedef" va_list as an array type. There is a code segment
in src/libCoom/errPrintfVX.c which assgined "va_list" value
to a "va_list" variable.
In 68K compiler, it is a simple pointer assignment. In PPC compiler,
it turns to be an array assginment which is not allowed in the
current compiler.
2) Board specific problems .
2-1) vxMemProbe() does not work on Force PPC board. Because of
this, some device/driver support routine fail to find VME modules.
We currently uses workaround to fix this problem. That is to supply
numbers of VME modules in a startup script, like:
nigpib_num_links=2
ht2992_num_cards=1
2-2)Slave A24 access to a main memory.
NI-1014, GP-IB interface board for VME from Natinal Instruments, uses
DMA to exchange data between the board and a cpu board. It uses slave A24
access to the main memory on the CPU board. Default settiing of BSP for
Force CPU disables slave A24 access.
2-3) Word bundary.
GP-IB driver for NI-1014 uses data structure cc_ary shown below:
struct cc_ary{
void *cc_ccb;
short cc_ONE;
void *cc_n_1addr;
short cc_TWO;
This structure relflects structure of registers on NI-1014 board and
should not be changed. However, compiler for Power PC add pad bytes between
cc_ccb and cc_ONE.
We have modified the structure as follows:
typedef struct DmaStuffStruct {
char cc_array[12];
char cc_byte;
> In particular, did anyone make use of the following drivers and
> did they have to make any code changes to get them working:
> "drvBc635" - Bancomm driver - not likely to have been used by anyone
> outside of this
> project.
> "drvXy240" - TTL Card.
> "drvXy566" - Analogue Input.
> "drvOms" - Motor controller.
> "drvTip810" - CanBus.
> "drvAb" - Allen-Bradley.
> "drvPmac" - PMAC Motion Controller.
Sorry, we use NONE of these driver in our system and don't have chance to
test them.
> Many thanks for your time,
> Andy
> Andy Foster
> Gemini 8-m Telescopes Project Tel: 1 (808) 933 7106 (direct)
> Suite 207 Fax: 1 (808) 933 7123
> Hilo Plaza E-mail: [email protected] or
> 180 Kinoole Street [email protected]
> Hilo
> Hawaii 96720
> USA
Best regards,
Noboru Yamamoto
Re: XVME 566 driver problem Bob Dalesio
Re: Power PC and EPICS William Lupton
<1998>
2025
2026
Power PC and EPICS Andy Foster
<1998>
2025
2026
