1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: increasing scan rates
To: "'Jeff Hill'" <[email protected]>, "'Geoff Savage'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 14 Aug 1998 13:46:13 -0600
For rates less than your vxWorks clock rate (default 60Hz) you can add
periodic scan rates to EPICS by modifying menuScan.ascii as described in
the IOC Applications Developers Guide. For R3.13 see Chapter 14. Database
Scanning.
The caveat is that your specified scan rates in seconds should map to a
integral number of clock ticks - otherwise you will not get the timing you
expect.
I've routinely used 20Hz (.05 second) scan rates for servo loops. This
would be implemented by adding the following to the menu(menuScan)
definition:
menu(menuScan) {
	choice(menuScan__5_second, ".05 second")
With a 60Hz vxWorks clock, this scan task gets processed once every 3
ticks.
Aloha,
	Peregrine
Peregrine M. McGehee				[email protected]
LEDA Control System Project Engineer 		(505) 667-3273
Accelerator Controls & Automation Group 	Los Alamos National Laboratory
Prev: RE: increasing scan rates Jeff Hill
Next: Re: increasing scan rates William Lupton
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
