1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MBBI, SHFT, and GDCT
To: Ralph Lange <[email protected]>
Cc: Andy Foster <[email protected]>, [email protected], [email protected]
Date: Mon, 17 Aug 1998 10:06:14 -0500
Ralph Lange wrote:
> > > The only problem could be Raw Soft Support, as there is no address
> > > information in the INP/OUT fields and SHFT will always be 0. Right?
> > But if SHFT were allowed to be set by GDCT, wouldn't it just be
> > overwritten by the device support layer in the cases where the device
> > support sets this field, thus making it work for all cases?
> Yup. I neither see any problems with the SHFT value made DCT accessible.
> What do you think, Marty?
I dont see a problem except that it may be confusing.
> Another workaround (as SHFT is DB accessible):
> Put a couple of dbpf commands at the end of the startup.command script
> (after iocInit) to set the SHFT fields.
I think I prefer this as a solution because using raw soft support will
not be used very often.
Note that this discussion also applys to mbbiRecord and mbboRecord as
well as to mbbiDirectRecord and mbboDirectRecord.
Marty Kraimer
Re: MBBI, SHFT, and GDCT Ralph Lange
Prev: Re: MBBI, SHFT, and GDCT Ralph Lange
Next: Re: MBBI, SHFT, and GDCT Tim Mooney
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MBBI, SHFT, and GDCT Paul Sichta
