1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MBBI, SHFT, and GDCT
To: "tech-talk" <[email protected]>
Date: Fri, 14 Aug 1998 11:55:31 -0400
Ralph is addressing my situation.  I should clarify that I'm using mbbi for
DTYP (raw) soft.  My mbbi device's INP link references a 24-bit value
sourced by a separate (CAMAC) record.  For example,   I want to specify mbbi
values derived from 2 bits,  starting at bit 9.
-ps
-----Original Message-----
To: [email protected] <[email protected]>; [email protected]
<[email protected]>
Date: Friday, August 14, 1998 11:35 AM
>> I am using gdct313 to define an MBBI record and there is no place on the
>> "Edit Attributes" form for specifying the number of bits to 'shift' the
raw
>> value (SHFT).  mbbiRecord.dbd does not assign the SHFT field to a
>> promptgroup.  Is there a reason for this omission ?
>> This situation also applies to record types mbbo,  mbbiDirect,  and
>> mbboDirect.
>The SHFT value is device dependent. In most cases it depends on the
>structure of the associated device and can be calculated from the address
>information in the INP/OUT field. So device support usually sets SHFT in
>initRecord() after parsing the INP resp. OUT fields.
>Making the SHFT field DCT accessible would introduce redundancy and
>most likely increase error probability.
>The only problem could be Raw Soft Support, as there is no address
>information in the INP/OUT fields and SHFT will always be 0. Right?
>Ralph
Re: MBBI, SHFT, and GDCT Ralph Lange
Prev: Re: MBBI, SHFT, and GDCT Ralph Lange
Next: Re: MBBI, SHFT, and GDCT Ralph Lange
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MBBI, SHFT, and GDCT Marty Kraimer
