> Ralph is addressing my situation. I should clarify that I'm using mbbi for
> DTYP (raw) soft. My mbbi device's INP link references a 24-bit value
> sourced by a separate (CAMAC) record. For example, I want to specify mbbi
> values derived from 2 bits, starting at bit 9.
Thought so. I missed that feature a couple of times, too. I used calc
records doing shifts as a workaround, but this is admittedly a crappy
solution.
But as the field definitions including DCT accessibility are fix ... I
don't really have a clue what to do with Raw Soft Support. I guess you
would find other fields that should be set by device support but aren't
with Raw Soft Support if you just look hard enough.
This gets more complicated while thinking about it ... time to leave for
the weekend, then.
Ralph
- Re: MBBI, SHFT, and GDCT Paul Sichta
VSD_2992 Base Address Paul Sichta
<1998>
2025
2026
Re: MBBI, SHFT, and GDCT Tim Mooney
<1998>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
