> I am using gdct313 to define an MBBI record and there is no place on the
> "Edit Attributes" form for specifying the number of bits to 'shift' the raw
> value (SHFT). mbbiRecord.dbd does not assign the SHFT field to a
> promptgroup. Is there a reason for this omission ?
> This situation also applies to record types mbbo, mbbiDirect, and
> mbboDirect.
The SHFT value is device dependent. In most cases it depends on the
structure of the associated device and can be calculated from the address
information in the INP/OUT field. So device support usually sets SHFT in
initRecord() after parsing the INP resp. OUT fields.
Making the SHFT field DCT accessible would introduce redundancy and
most likely increase error probability.
The only problem could be Raw Soft Support, as there is no address
information in the INP/OUT fields and SHFT will always be 0. Right?
Ralph
- Re: MBBI, SHFT, and GDCT Andy Foster
- MBBI, SHFT, and GDCT Paul Sichta
Re: MBBI, SHFT, and GDCT Andrew Johnson
Re: MBBI, SHFT, and GDCT Paul Sichta
<1998>
2025
2026
<1998>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
