Arne:
>I am presently using a IP Octal Serial card from greenspring
>to accomodate the serial devices. However the serial lines on
>this card default to 9600 baud, 8 data bits no parity....
>I've looked in to the Vxworks tyLib package and can only find
>function calls to change the baud rate, and another OPT_7_BIT which
>I think will place the port in 7 data bit mode.
How did you manage to call the IP octal at all with the
standard VxWorks drivers?
As far as I know it is not supported by VxWorks if you
just plug it in.
I've used an IP-octal at DESY where they had bought
a special driver for it from SOFTEC GmbH, 89073 Ulm, Germany.
It comes with a file called ip8s.h that defines
some additional bits for ioctl(): speed, 5,6,7,8 bits, even,odd,no parity etc.
I extended it with the necessary bits from the IP octal manual
so that I could use mark/space "parity":
#define OPT_SPACE 0x08
#define OPT_MARK 0x0C
>What I cannot find is a way to put the port in parity=odd and
>to look for 1 stop bit.
If your driver will just use whatever is given to ioctl()
and set the mode register, e.g.:
ioctl (fd, FIOPARITY, OPT_EVEN)
will end up like this in the driver code:
case FIOPARITY:
status = ip8sMRSet(pip8sDv, arg, PARITY_MASK ,0,0);
then you can use the actual hardware bits:
#define OPT_NONE 0x10
#define OPT_EVEN 0x00
#define OPT_ODD 0x04
#define OPT_STOP_1_0 0x07
#define OPT_STOP_1_5 0x08
#define OPT_STOP_2_0 0x0f
So with the proper driver it should pose no problem, you can just use:
ioctl (m->fd, FIOSETOPTIONS, OPT_RAW)
ioctl (m->fd, FIOBAUDRATE, 1200)
ioctl (m->fd, FIOCHARSIZE, OPT_7BITS)
ioctl (m->fd, FIOPARITY, OPT_EVEN)
ioctl (m->fd, FIOSTOPBITS, OPT_STOP_1_0)
for example.
Unfortunately I cannot send you the driver code from SOFTEC
without being shot because of copyright violation...
But if you have any questions please feel free to bug me.
-Kay
et_wish on Solaris 2.6 Garrett D. Rinehart
Thanks to all! Jin Yu
<1998>
2025
2026
FW: Serial Configuration on a Greenspring Octal serial IP Peregrine McGehee
EPICS and Solaris 2.6 Frederick Carter
<1998>
2025
2026
