1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Power PC floating point underflow
To: [email protected]
Date: Fri, 23 Oct 1998 09:07:51 -0500
William Lupton wrote:
>   Overflows, underflows and divide by zeroes are all errors and it is
> reasonable that they should cause exceptions. Would there be any
> support, though, for providing an architecture-independent method for
> controlling them (e.g. a hook routine that would be called whenever
> EPICS created a task)?
On my mv167 the following test
int exctest()
   float x,y,z;
   int i,j,k;
   x = 1e35;
   y = 0.0;
   z = x/y;
   printf("x %e y %e z %e\n",x,y,z);
   x = 1e35;
   y = 1e35;
   z = x*y;
   i = 100000;
   j = 100000;
   k = i*j;
   printf("i %d j %d k %d\n",i,j,k);
   i=1;
   j=0;
   k = i/j;
   return(0);
produces
exctest
x 1.000000e+35 y 0.000000e+00 z Inf
x 1.000000e+35 y 1.000000e+35 z Inf
i 100000 j 100000 k 1410065408
Zero Divide
Program Counter: 0x007fdc40
Status Register: 0x3000
Access Address : 0x007fdc3c
Thus only divide by zero is being trapped.
I also have three comments about:
1) It is not clear that under flows should be errors. For many
algorithms they can be expected. Back in my IBM scientific programming
days I wrote an assembly routine, callable by fortran, that turned off
underflow exceptions. It was widely used and not just by myself.
2) In c it has been common for implementations to ignore integer
overflow. It will be interesting to see what fails if these are now
trapped.
3) If we start trapping 1) or 2) what should we do? one possibility is:
a) provide a handler that issues an error and continues.
b) provide the ability for user code to temporily disable trap or
provide alternate handler.
Marty Kraimer
Power PC floating point underflow William Lupton
Prev: Power PC floating point underflow William Lupton
Next: Re: Power PC floating point underflow William Lupton
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
