Hi there.
During the last couple of days I spent some efforts to get binutils-2.9.1
/ gcc2.8.1 / gdb4.17 to work on our Linux / hpux10.20 platforms.
(The gcc that was shipped with our vxWorks5.2 was still gcc2.2.3.1 and
there is no Linux version of course.) It was surprisingly easy and after
tweaking CONFIG_SITE.Vx & friends, EPICS-3.13.0.beta12 compiled successfully
for the mv162 and mv167 targets under Linux (yes, it is possible to develop
server side code under Linux -- I mean, I don't know about the legal issues,
i. e. if the vxWorks license allows for using the headers under gcc/Linux).
However, I'd like to post some minor problems I came across:
vxWorks apparently was compiled using the -freg-struct-return option for
gcc which allows for returning small structures in a register. By default,
this option is disabled however. I strongly recommend to insert
the line
/* set DEFAULT_PCC_STRUCT_RETURN to 0 for compat with vxWorks5.2 */
#define DEFAULT_PCC_STRUCT_RETURN
0
at the end of the file vxm68k.h in the gcc-2.8.1/config/m68k subdirectory.
This applies for all host architectures.
Note that objects compiled with different settings of this option must
not be linked together. The linker doesn't complain, but the function
return values are wrong. This is nasty, because only functions which return
small structs are affected and these are not very frequent...
While building the cross linker (GNU binutils-2.9.1) under hpux, the SHLIB_PATH
environment variable interferes with a makefile-variable of the same name
and the linker script is incorrectly built. Make sure the dynamic loader
(hpux' loader, not the one that is being compiled) doesn't need any of
the paths listed in SHLIB_PATH and unset this variable during the build.
If this is not possible, you have to change the mentioned makefile variable
in the Makefiles, the script templates etc. As an alternative you may fix
the linker script by hand.
There were no problems with gdb4.17 (I using it with the DDD2.2 frontend)
which provides a nice development environment at low cost -- thank the
GNU --.
Hope to meet you people soon in Berlin, Till.
Re: portable CA server user survey john sinclair
Frame grabber and Portable channel access Miroslaw Dach
<1998>
2025
2026
Re: Conditional processing of links Andy Foster
<1998>
2025
2026
