1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE:PC Fonts....
To: [email protected]
Date: Fri, 11 Dec 1998 10:14:42 EST
Hello all,
Bonnie Madre asked some days ago for fonts nessesary for MEDM used on a
PC via PC-Xware. I am using MEDM in that way. I included a font-server
path into my setup: hale.desy.de:7890 , where 7890 is the port-nr. Perhaps
you can try to test it and perhaps copy fonts from there (if the firewall
allows it).
A second hint I can give is how to configure the graphic display. I tried
al lot of settings! Windows, Netscape, MEDM, IDL and other X-Apps are
running without getting out of colors when I set the number of colors
to 256 and enable the pallette function of the graphic board.
Hope that it helps...
Bernd Schoeneburg
Prev: constant links with strings Peregrine McGehee
Next: Re: Monitors on a stringin record Tim Mooney
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: PC Fonts.... Ken Evans
Next: CDEV activities Chip Watson
