Please find included a short routine to convert CA links to CONSTANT links.
I needed this to allow use of strings in CapFast hardware inputs to genSub
records.
As has been previously discussed in tech-talk, dbPutString() assumes that
if a link can not be completed parsed by strtod() then it must be a process
variable rather than a constant. Besides impacting full use of the genSub
record, this has also been a bane for those wishing to initialize string
records.
Rozelle Wright mentioned a proposal to modify the dbPutString logic to
allow links to include a special leading character such as '$' to indicate
that this really is a constant value. Although the routine described here
solves the problem for genSub records it does not address the issue for
string records.
Several implementation points:
1) The genSub record invokes the user supplied initialization routine on
the second record initialization pass during iocInit. If the code listed
below was called in the first pass, the dbCaRemoveLink() call would be
unnecessary and the link type would be PV_LINK rather than CV_LINK or
DB_LINK.
2) The transfer of data between the pv_link and constantStr could be
considerably simplified by leveraging off the alignment of the elements
within the plink->value union. However, this is more robust and follows the
logic in dbCvtCaLinkToConstant() in dbStaticLib.
3) The call to recGblInitConstantLink() is required due to the order of
operations in the genSub init_record().
long
rpCvtCaLinkToConstant(struct link *plink, short dbfType, void * valptr)
char str[MAX_STRING_SIZE];
if (plink->type == CONSTANT) return OK;
if (plink->type != CA_LINK) return ERROR;
/* Tell the dbCaLink task to forget this PV. */
dbCaRemoveLink(plink);
/* Save the PV name and clean up. */
strcpy(str, plink->value.pv_link.pvname);
free(plink->value.pv_link.pvname);
/* Create the new CONSTANT link. */
plink->type = CONSTANT;
plink->value.constantStr = dbCalloc(strlen(str) + 1, sizeof(char));
strcpy(plink->value.constantStr, str);
/* Initialize the CONSTANT link. */
recGblInitConstantLink(plink, dbfType, valptr);
return OK;
Aloha,
Peregrine
Peregrine M. McGehee Task Leader, LEDA Control System
Deputy Coordinator, Los Alamos Astrophysics http://laastro.lanl.gov
(505) 667-3273 MS H820, LANL, Los Alamos, NM 87545
Re: Monitors on a stringin record Marty Kraimer
RE:PC Fonts.... schoeneburg
<1998>
2025
RE: Links between IOCs Jeff Hill
Activity logging Rolf Keitel
<1998>
2025
