John,
If the IOCs are not on the same IP subnet then you will need to add an IP route
to enable communication. There is a "ping" program supplied with tornado that can
be used to test IP communication at a primitive level. There is also information
concerning the configuration of EPICS for multi-subnet networks in the CA reference
manual.
Jeff
On Friday, December 11, 1998 12:31 PM, Hammonds, John [SMTP:[email protected]] wrote:
> This suggestion from Mark has done the trick. According to some E-mails
> that I have seen it seems somewhat random when this is needed. Does anyone
> know why things work sometimes and not others?
> John
> > -----Original Message-----
> > From: Mark Rivers [SMTP:[email protected]]
> > Sent: Thursday, December 10, 1998 8:14 PM
> > To: [email protected]
> > Cc: [email protected]; [email protected]
> > Subject: RE: Links between IOCs
> > Are you sure that CA links between IOCs are working at all? You need to
> > put
> > lines in your st.cmd like the following:
> > # Set the default gateway
> > routeAdd "0","164.54.160.65"
> > # Don't use the gateway for machines on this subnet
> > routeDelete "164.54.160.64","164.54.160.65"
> > Mark Rivers
RE: Monitors on a stringin record Jeff Hill
Re: tkCVS - tk based GUI for CVS Brian McAllister
<1998>
2025
2026
RE: Links between IOCs Hammonds, John
constant links with strings Peregrine McGehee
<1998>
2025
2026
