1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Monitors on a stringin record
To: "'Marty Kraimer'" <[email protected]>, Ralph Lange <[email protected]>
Cc: Mark Rivers <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 11 Dec 1998 14:08:58 -0700
On Friday, December 11, 1998 8:03 AM, Marty Kraimer [SMTP:[email protected]] wrote:
> Ralph Lange wrote:
> > > I have a naive question here.  I was under the impression that even if a
> > > record requested that monitors be posted on a field which had not changed,
> > > that channel access would not actually post the monitors if the values were
> > > the same.  Is this true?
Strictly speaking, when record support calls db_post_events() a monitor event is always
added to the servers event queue if there is quota. If there is not quota then the last event
on the queue is replaced. Contrary to my interpretation of Mark's impression above,
there is _not_ any event suppression in or below db_post_events() where the post event request
is ignored if the monitored value has not changed significantly since the last event. The responsibility
for this sort of event compression is left solely to the situation specific needs of dbCommon
and record support.
Jeff
Prev: ALH Garrett D. Rinehart
Next: RE: Links between IOCs Jeff Hill
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Monitors on a stringin record Tim Mooney
Next: Links between IOCs Hammonds, John
