re...
> > > The make rules will use soft links to the share/db directory on unix
> > > systems and copy the shared templates to the application under WIN32.
> > It might be nice to have similar treatment for db files.
> Try changing line 46 in RULES.Db:
> < $(notdir $(TEMPLATE_LINKS)): %.template:
> > $(notdir $(TEMPLATE_LINKS)): %:
> This should make the link/copy mechanism of USES_TEMPLATE work for any file
> name. Please tell me if this works, for it might be considered a permanent
> change then.
No luck. That gets .db files from share into the O.<arch> directory, but it's
tough sledding from there, because make is frantic about dependencies on
.db files in that directory.
I ended up with something that copies straight from share into the install
directory and is derived your code involving the symbol TEMPLATE_LINKS.
The user specifies the new symbol DB_LINKS in Makefile.Host, like so
DB_LINKS += $(SHARE)/stdApp/Db/motor.db
and this gets treated by the following lines added to RULES.Db
ifneq '$(DB_LINKS)' ''
build:: $(notdir $(DB_LINKS))
endif
$(notdir $(DB_LINKS)):
@$(RM) $(addprefix $(INSTALL_DB)/, $(notdir $(DB_LINKS)))
ifndef WIN32
ln -s $(DB_LINKS) $(INSTALL_DB)
else
$(CP) $(DB_LINKS) $(INSTALL_DB)
endif
This works and doesn't appear to have any side effects.
I also have modified copies of dbLoadRecords and dbLoadTemplate so that
they work with a path argument, and are backward compatible with the standard
calling syntax.
Tim
Re: tkCVS - tk based GUI for CVS Guy Jennings
Re: ALH Maren Purves
<1998>
2025
2026
Re: living without soft links Ralph Lange
tkCVS - tk based GUI for CVS Ralph Lange
<1998>
2025
2026
