1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wdTimer & EPICS sequencer
To: [email protected]
Cc: Tech_Talk <[email protected]>
Date: Sat, 30 Jan 1999 11:15:50 -0600
"Russell J. Page, Sr." wrote:
> I'm presently trying to resolve a problem in an EPICS Sequencer Program.
> I need to create a delay and the SNL delay function is unsuitable for
> what I need to do.
It would help if you explain a little more about what you actually want to
occur and why the SNL delay function can't do what you want.  I'm not sure
a watchdog timer would be your best solution, but without understanding
the problem it's hard to suggest alternatives (eg would calling taskDelay
in an action statement solve this?).
> Using the escape mechanism with a usr function, I am
> able to create a vxWorks watchdog timer okay, but when the timer
> expires, I need to return to the sequencer code. At present, my test
> timer returns a message to my debug terminal as I expect (I use the
> printf function). I tried every permutation I can think of on the idea
> of exit(), wdDelete, wdCancel, etc. but all that happens is either a
> reboot of the target or the terminal hangs. ^C, ^Z etc. won't break it.
The watchdog callback function is executed within ISR context; you can get
all kinds of crashes if you're not careful here.  Check the vxWorks users
manual for information on what is & is not allowed.
- Andrew
New country, job, address, car and signature; same old Andrew Johnson
wdTimer & EPICS sequencer Russell J. Page, Sr.
Prev: wdTimer & EPICS sequencer Russell J. Page, Sr.
Next: dbst problem when built against 3.13.1 saa
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
