Andy Foster wrote:
> Dear All,
> Apparently OMS are replacing the VME8-8 with VME58-8.
> Is anyone using the new card with EPICS 3.12.2?
A number of experimenters at the Advanced Photon Source
have been using the OMS VME58-8 since I have been here
(1/98) without any major problems.
> Can anyone tell me if the EPICS driver supports this new card without
> changes?
Of course, there are always changes.
Support for the OMS VME58-8 extends back to at least
Motor Record version 2.3; I don't know if any earlier
versions of the Motor Record supported the VME58.
The differences between the "oms" and "oms58" device
drivers are minor in terms of the "st.cmd" file. Simply
add an additional setup line for the "oms58" as follows,
# OMS VME driver setup parameters:
# (1)cards, (2)axes per card, (3)base address(short, 16-byte
boundary),
# (4)interrupt vector (0=disable or 64 - 255), (5)interrupt level
(1 - 6),
# (6)motor task polling rate (min=1Hz,max=60Hz)
omsSetup(5, 8, 0xFC00, 180, 5, 10)
# OMS VME58 driver setup parameters:
# (1)cards, (2)axes per card, (3)base address(short, 4k boundary),
(1 - 6),
oms58Setup(5, 8, 0x3000, 190, 5, 10)
Please be aware that there are some known problems with
earlier Motor Record releases (i.e., anything before
Version 3.4). See below for problem description,
http://www.aps.anl.gov/xfd/SoftDist/swBCDA/motor_V3.4.html
As long as we are on the topic of OMS VME58 boards;
Attention anyone out there with OMS VME58-8S boards.
OMS has upgraded EPROM U78 to BV52.2-8S. This
fixes a bug that caused the VME58-8S board to be
unavailable on the VME bus every other time after
a VMEbus System Reset.
Ron Sluiter
- OMS Support Andy Foster
Re: OMS Support Tim Mooney
<1999>
2025
2026
<1999>
2025
2026
