1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Unique Channel Names???
To: "'Natalie Otey'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 8 Mar 1999 10:02:14 -0700
On Monday, March 08, 1999 9:05 AM, Natalie Otey [SMTP:[email protected]] wrote:
> Hi,
> I'm running two identical systems with identical databases on the same
> network. When attempting to run MEDM, it says that it sees the requested
> channel on two different IOCs. This is because the databases are identical.
> Do the channels names need to be unique??
Yes, the channel names uniquely determine the process variable that is the
end point of communication so you must have only one channel with a particular
name in each EPICS system.
However, if you configure the port numbers that are used by the EPICS CA client and
the EPICS CA server then you can run several independent EPICS systems with
overlapping process variable (channel) name spaces on the same local area network
(IP subnet). Details on EPICS CA configuration are on the WEB in the CA reference
manual.
It is also a common practice to embed process variable name prefix macros in the record
names so that it is easy to retarget the all of the record names in a test database at load time.
Jeff
Prev: Unique Channel Names??? Natalie Otey
Next: What's new on EPICS Software Distribution Page! Bakul Banerjee
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Unique Channel Names??? John A. Priller
Next: RE: Unique Channel Names??? Jeff Hill
