I'm using EPICS R3.13.1 on Sun Solaris 2.6 w/gcc 2.8.1, and I had that same
"internal compiler error" message in exactly the same place. I got around
it by manually compiling gdd.cc without optimization (that long string of
arguments, minus the -O flag) and moving the resultant gdd.o file to my
O.solaris subdirectory. I haven't actually tried using gdd on the Sun, so I
don't know if that's a completely valid work-around, but I was able to
finish the build.
If anyone's curious, I did a little tinkering with the gdd code while I was
trying to find the problem, and it seems to result from gdd::init (and
gdd::setDimension) casting a pointer to gddBounds1D (or 2D, 3D) to a pointer
to gddBounds. At least commenting out those lines kept the error from
occuring.
John A. Priller | Phone : (517) 333-6375
MSU Cyclotron Laboratory | Fax : (517) 353-5967
South Shaw Lane | Email : [email protected]
East Lansing, MI 48824 | Web : http://prille.nscl.msu.edu/jp.html
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: Tuesday, March 09, 1999 6:05 PM
> To: tech talk
> Subject: Installing epics on Sun Solaris
> I just got my new Solaris machine going and attempted the
> EPICS R3.13.1
> install.
> All my GNU tools were downloaded in binary form from a Sun site.
> Environment vars:
> EPICS_BASE=/epics/base
> HOST_ARCH=solaris
> I do this:
> cd /epics/base
> make
> I get this:
> make -C src inc
> make[1]: Entering directory `/space/epics/base/src'
> make -C tools inc
> make[2]: Entering directory `/space/epics/base/src/tools'
> /usr/bin/perl ../../bin/solaris/makeMakefile.pl O.solaris Host
> Can't open perl script "../../bin/solaris/makeMakefile.pl":
> No such file or directory
> make[2]: *** [O.solaris] Error 2
> make[2]: Leaving directory `/space/epics/base/src/tools'
> make[1]: *** [tools.inc] Error 2
> make[1]: Leaving directory `/space/epics/base/src'
> make: *** [src.inc] Error 2
> This must be a simple problem. Any suggestions?
> To get things to go a little farther, I manually created
> bin/solaris and copied the perl scripts.
> Then I do this:
> cd /epics/base
> make
> I get this:
> Entering directory `/space/epics/base/src/gdd/O.solaris'
> ../../../config/RULES.Host:461: target `../../../javalib'
> given more than once in the same rule.
> /usr/local/bin/g++ -ansi -pedantic -Wtraditional -O -Wall
> -Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings
> -Wconversion -Wstrict-prototypes -Wpointer-arith -Winline
> -DSOLARIS -DUNIX -DEXPL_TEMPL -I. -I..
> -I../../../include -I../../../incl
> ude/os/solaris -fPIC -c ../genApps.cc
> ude/os/solaris -fPIC -c ../gdd.cc
> ../gdd.cc: In method `void gdd::init(int, enum aitEnum, int)':
> ../gdd.cc:189: Internal compiler error.
> ../gdd.cc:189: Please submit a full bug report to
> `[email protected]'.
> make[3]: *** [gdd.o] Error 1
> make[3]: Leaving directory `/space/epics/base/src/gdd/O.solaris'
> make[2]: *** [inc.solaris] Error 2
> make[2]: Leaving directory `/space/epics/base/src/gdd'
> make[1]: *** [gdd.inc] Error 2
> So is my g++ compiler version not compatible?
> g++ -v gives:
> Reading specs from
> /usr/local/lib/gcc-lib/sparc-sun-solaris2.7/2.8.1/specs
> gcc version 2.8.1
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 423-576-6362 423-574-1268 (fax)
- Re: Installing epics on Sun Solaris Guy Jennings
- Installing epics on Sun Solaris john sinclair
<1999>
2025
2026
<1999>
2025
2026
