You might also like to try egcs instead of gcc/g++, I gather it is superior for
c++, especially on non-Intel platforms...
"John A. Priller" wrote:
> I'm using EPICS R3.13.1 on Sun Solaris 2.6 w/gcc 2.8.1, and I had that same
> "internal compiler error" message in exactly the same place. I got around
> it by manually compiling gdd.cc without optimization (that long string of
> arguments, minus the -O flag) and moving the resultant gdd.o file to my
> O.solaris subdirectory. I haven't actually tried using gdd on the Sun, so I
> don't know if that's a completely valid work-around, but I was able to
> finish the build.
> If anyone's curious, I did a little tinkering with the gdd code while I was
> trying to find the problem, and it seems to result from gdd::init (and
> gdd::setDimension) casting a pointer to gddBounds1D (or 2D, 3D) to a pointer
> to gddBounds. At least commenting out those lines kept the error from
> occuring.
> John A. Priller | Phone : (517) 333-6375
> MSU Cyclotron Laboratory | Fax : (517) 353-5967
> South Shaw Lane | Email : [email protected]
> East Lansing, MI 48824 | Web : http://prille.nscl.msu.edu/jp.html
> > -----Original Message-----
> > From: john sinclair [mailto:[email protected]]
> > Sent: Tuesday, March 09, 1999 6:05 PM
> > To: tech talk
> > Subject: Installing epics on Sun Solaris
> > I just got my new Solaris machine going and attempted the
> > EPICS R3.13.1
> > install.
> > All my GNU tools were downloaded in binary form from a Sun site.
> > Environment vars:
> > EPICS_BASE=/epics/base
> > HOST_ARCH=solaris
> > I do this:
> > cd /epics/base
> > make
> > I get this:
> > make -C src inc
> > make[1]: Entering directory `/space/epics/base/src'
> > make -C tools inc
> > make[2]: Entering directory `/space/epics/base/src/tools'
> > /usr/bin/perl ../../bin/solaris/makeMakefile.pl O.solaris Host
> > Can't open perl script "../../bin/solaris/makeMakefile.pl":
> > No such file or directory
> > make[2]: *** [O.solaris] Error 2
> > make[2]: Leaving directory `/space/epics/base/src/tools'
> > make[1]: *** [tools.inc] Error 2
> > make[1]: Leaving directory `/space/epics/base/src'
> > make: *** [src.inc] Error 2
> > This must be a simple problem. Any suggestions?
> > To get things to go a little farther, I manually created
> > bin/solaris and copied the perl scripts.
> > Then I do this:
> > cd /epics/base
> > make
> > I get this:
> > Entering directory `/space/epics/base/src/gdd/O.solaris'
> > ../../../config/RULES.Host:461: target `../../../javalib'
> > given more than once in the same rule.
> > /usr/local/bin/g++ -ansi -pedantic -Wtraditional -O -Wall
> > -Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings
> > -Wconversion -Wstrict-prototypes -Wpointer-arith -Winline
> > -DSOLARIS -DUNIX -DEXPL_TEMPL -I. -I..
> > -I../../../include -I../../../incl
> > ude/os/solaris -fPIC -c ../genApps.cc
> > ude/os/solaris -fPIC -c ../gdd.cc
> > ../gdd.cc: In method `void gdd::init(int, enum aitEnum, int)':
> > ../gdd.cc:189: Internal compiler error.
> > ../gdd.cc:189: Please submit a full bug report to
> > `[email protected]'.
> > make[3]: *** [gdd.o] Error 1
> > make[3]: Leaving directory `/space/epics/base/src/gdd/O.solaris'
> > make[2]: *** [inc.solaris] Error 2
> > make[2]: Leaving directory `/space/epics/base/src/gdd'
> > make[1]: *** [gdd.inc] Error 2
> > So is my g++ compiler version not compatible?
> > g++ -v gives:
> > Reading specs from
> > /usr/local/lib/gcc-lib/sparc-sun-solaris2.7/2.8.1/specs
> > gcc version 2.8.1
> > John Sinclair
> > [email protected]
> > Oak Ridge National Lab
> > 423-576-6362 423-574-1268 (fax)
- RE: Installing epics on Sun Solaris John A. Priller
Installing epics on Sun Solaris john sinclair
<1999>
2025
2026
<1999>
2025
2026
