Hi Andy,
we run 2300 boards, but I assume they are similar to the 2700. I further assume
you have vxWorks set up on
your system. So here's what I have done:
- in the bsp directory
$ make bootrom_uncmp
$ elfToBin < bootrom_uncmp > mv2300.boot
- copy mv2300.boot to the /tftpboot directory. ( tftp deamon must be running )
- the mv2300 board comes with two flash memory banks A and B switchable through
jumper J15.
Factory setting is bank A ( pins 1 and 2 are jumpered ). Both banks come with
Motorola's PPCBug loaded.
Jumper pin 2 and 3 to select bank B. Power up the crate.
- set the time ( necessary: in my case it didn't work without)
( following a log of a session, input is in brackets )
PPC1-Bug> <set 0115991705> # FRI JAN 15 17:05:00.00 1999
- run niot to configure the network , e.g.
PPC1-Bug> <niot>
Controller LUN =00?
Device LUN =00?
Node Control Memory Address =01F9E000?
Client IP Address =0.0.0.0? <129.129.10.23>
Server IP Address =0.0.0.0? <129.129.40.123>
Subnet IP Address Mask =255.255.255.0? <255.255.0.0>
Broadcast IP Address =255.255.255.255? <129.129.0.0>
Gateway IP Address =0.0.0.0? <129.129.100.2>
Boot File Name ("NULL" for None) =? <mv2300.boot>
Argument File Name ("NULL" for None) =?
Boot File Load Address =001F0000?
Boot File Execution Address =001F0000?
Boot File Execution Delay =00000000?
Boot File Length =00000000?
Boot File Byte Offset =00000000?
BOOTP/RARP Request Retry =00?
TFTP/ARP Request Retry =00?
Trace Character Buffer Address =00000000?
BOOTP/RARP Request Control: Always/When-Needed (A/W)=W?
BOOTP/RARP Reply Update Control: Yes/No (Y/N) =Y?
Update Non-Volatile RAM (Y/N)? <y>
PPC1-Bug>
- run niop to download mv2300.boot
PPC1-Bug> <niop>
Controller LUN =00?
Device LUN =00?
Get/Put =G?
File Name =? <mv2300.boot>
Memory Address =00004000?
Length =00000000?
Bytes Received =&358812, Bytes Loaded =&358812
Bytes/Second =&89703, Elapsed Time =4 Second(s)
- load mv2300.boot into memory bank A:
PPC1-Bug>pflash 4000:100000 ff000100
Source Starting/Ending Addresses =00004000/01003FFF
Destination Starting/Ending Addresses =FF000100/000000FF
Number of Effective Bytes =01000000 (&16777216)
Program FLASH Memory (Y/N)? <y>
FLASH Memory Programming Complete
PPC1-Bug>
- power down the create and rejumper J15 to memory bank A. Repower the crate and
the vxWorks prompt should pop up.
- finally set up the nvram to boot the vxworks system image.
processor number : 0
host name : pc1784
file name : /home/ioc/ioc001/vxWorks
inet on ethernet (e) : 129.129.10.1
host inet (h) : 129.129.77.34
user (u) : ioc
flags (f) : 0x0
target name (tn) : ioc001
startup script (s) : startup.script
Cheers,
Detlef
Detlef Vermeulen phone: +41 56 310 3620
Paul Scherrer Institute fax: +41 56 310 4413
SLS Computing & Controls mailto: [email protected]
Andy Foster wrote:
> Dear All,
> Does anyone have a prescription to set up the
> booting of an mvme2700 from PPCBug using the tftp
> network protocol?
> Cheers,
> Andy
> Andy Foster
> Gemini 8-m Telescopes Project Tel: 1 (808) 974 2556 (direct)
> Gemini-North Base Facility Fax: 1 (808) 935 9235
> 670 North A'ohoku Place
> University Park E-mail: [email protected] or [email protected]
> Hilo Home Page: http://controls.gemini.edu/ajf
> Hawaii 96720
> USA
- tftp Booting of mvme2700 Andy Foster
GDCT 313 BOGARD Daniel
Re: GDCT 313 Bakul Banerjee
<1999>
2025
2026
<1999>
2025
2026
