1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on x86
To: [email protected], [email protected]
Date: Mon, 15 Mar 1999 17:05:53 +0100 (MET)
John Sinclair <[email protected]>:
> I do:
>   makeBaseApp.pl -t example example
> and it complains:
>   Not a directory Copying /usr/util/epics/base/templates/makeBaseApp/top/ ...
>   exampleApp/Makefile/.wind -> exampleApp/Makefile/.wind at /usr/util/ ...
>   epics/base/bin/sun4/makeBaseApp.pl line 249.
Brian McAllister <[email protected]>:
> Back in December, there was a conversation on TechTalk about makeBaseApp
> failing because it tried to copy a non-existent file.  In that case, the
> file was .../Makefile/.wind.  I am having exactly the same problem, except
> that in my case the file is .../Makefile/.cshrc.
John Sinclair again:
> All appears well until dbLoadDatabase which fails and gives the
> following console message:
>   Error "syntax error"  Last token ".bashrc"
>   input line: .bashrc
>      in: file /usr/users/sinclx86/hribfx86/dbd/exampleApp.dbd line 1
>   db_parse returned -1
The most obvious common thing is the Solaris OS.
Could these strange things be due to a Solaris bug or misconfiguration that
somehow scrambles up processes that try to read files?
Ralph
Re: EPICS on x86 Brian McAllister
EPICS on x86 john sinclair
Prev: devVXStats.c corrupts Intel floating point unit Jeff Hill
Next: Re: EPICS on x86 Brian McAllister
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS on x86 john sinclair
