1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: TCP s_errno_ENOBUFS error in CAS
To: "Tech-Talk (E-mail)" <[email protected]>
Cc: [email protected]
Date: 18 Mar 99 15:10:35 +0900
Occasionally , we lost CA connectin to the one of IOCs in our system.
Checking the console log, we found the following messages.
> 0x15b7fe0 (CA event): CAS: TCP send to "172.19.xx.xx" failed because
"S_errno_ENOBUFS"
and
>iocLogClient: no socket error S_errno_ENOBUFS
before IOC   was rebooted. First message repeated several times. Then
several of second message follows.
In listserve archive, I found the message from J.Hill on similar subjetc.
File /Public/asd/controls/epics/maillists/tech-talk/199808/19980828.html
However, It discusses the error messge:
> 1998-08-27,22:57:08: 0xc2e7d4 (CA UDP): CAS: UDP send to "xx.xx.xx.xx"
failed
> because "S_errno_ENOBUFS"
"TCP sendto" is causing error message in our case, so the discussion in the
listserve archive may not apply.
Any suggestion to avoid this message will be greatly appriciated.
Thank you,
Noboru Yamamoto
KEKB control group
KEK, JAPAN
Prev: May Collaboration Meeting Bob Dalesio
Next: Re: TCP s_errno_ENOBUFS error in CAS Frank Lenkszus
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
