1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: TCP s_errno_ENOBUFS error in CAS
To: [email protected]
Date: Thu, 18 Mar 1999 06:07:37 -0600 (CST)
Your ioc is probably either out of memory or mbufs. Use memShow to check on
memory  usage and mbufShow to check on mbuf usage. As far as mbufs go, on our
iocs the max is 1500. If "number of mbufs:" = 1500 and/or "number of times
 drained protocols for space:" is  greater than 0 you're probably out of mbufs.
 This happens to us on an  ioc. We believe that workstation processes post
 monitors on PVs but then never service them. Buffers on the workstation fill to
 a system maximum, then mbufs on the ioc are allocated and filled to the
 1500 max. We can identify the workstations involved, have not been able to
 associate a socket with a process to figure out what process(es) are involved
 (on the workstation). The only way arround the out of mbufs problem is to
 either reboot the workstation(s) or the ioc. We reboot the ioc.
 Frank
Prev: TCP s_errno_ENOBUFS error in CAS Noboru Yamamoto
Next: database race condition? Till Straumann
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: TCP s_errno_ENOBUFS error in CAS Jeff Hill
