Marty Kraimer wrote:
> If each get/put is locked in addition to locking the lock set then database
> access must also lock each get/put. On an mv167 it taks about 50 microseconds to
> process a soft ai records which fetches a value from another record via a
> DB_LINK. It takes several microseconds (I cant remember the number but I think
> it was something like 5) to do a semTake,semGive. Thus it is a significent cpu
> overhead to lock each get/put.
I completely agree. That's why I suggested to just disable interrupts while copying
small multiple word data types (such as scalar doubles). This should be quite
efficient
and not affecting interrupt latency very much.
AFAIK, this could be done at a small number of places, namely in the
putXXXDouble routines.
Regarding string fields, it's probably the easiest to drop the NPP NMS exception for
such fields.
The `pointer alternative' i.e. adding an extra level of indirection to database links
and atomically switching a pointer before and after copying fields of more complex
data in order to always refer to valid data, would probably imply major changes.
The overhead however would not be outragous (one extra pointer deref)
- considering the fact that in many cases the `old' or `last' value of a field is
already buffered.
Well, I don't want to get on your nerves too much with this issue ;-) As I said, I
have no
problem with the current behavior - I was just wondering.
Best regards
Till Straumann.
- Re: database race condition? Andrew Johnson
- database race condition? Till Straumann
- Re: database race condition? Marty Kraimer
- Re: database race condition? Till Straumann
Time Stamping Natalie Otey
Re: Time Stamping Ned Arnold
<1999>
2025
2026
<1999>
2025
2026
