> Hello,
> We need to time stamp our data. The customer has suggested using a soft
> channel. Is that the best way?
> And how would that be implemented?
> Any other ideas on how to do this?
> I'm relatively new to EPICS so feel free to be very thorough and simple.
> Thanks!!!
> Natalie Otey
> KineticSystems
Each EPICS record has a "time stamp" field (.TIME) that gets updated
every time the record processes. The Time Stamp is available via a channel
access option and is used by many clients (archiver, alarm handler, etc).
If the record only processes when "new data" is available (such as due to
an interrupt), the time stamp field is very useful. It is also useful
for passive output records. medm will show the time stamp of a record using its
PV Info tool, which is frequently used here to see when a process variable
was last "controlled". The time stamp is not very useful for periodically
scanned records (other than informing you it is still scanning periodically !).
The format of .TIME is not very user friendly. You cannot fetch it directly
from channel access (using a caget) and even if you could you would end up
with a structure of two long unsigned INTs (or something like that). That is
why some have written device support for a string record which converts
the time stamp of a record to a string such as ...
03/19/99 07:36:07.064915
which can then be conveniently displayed in medm. The disadvantage is that
it requires a record for each time stamp you want. The code is very simple:
tsStampToText(&psi->time, TS_TEXT_MMDDYY, psi->val);
Without additional hardware, these timestamps have the resolution of the
vxWorks tick clock (60 Hz for us). With custom hardware, we have some
ioc's sync'd to within 1 microsecond.
Hope that helps get you started. There are better experts out there than
me !
Ned
Re: database race condition? Till Straumann
Re: database race condition? Andrew Johnson
<1999>
2025
2026
Time Stamping Natalie Otey
FW: slow VxWorks boot under Solaris 2.6 Jeff Hill
<1999>
2025
2026
