1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: problems with OMS motor controller and power pc cpu board mv2306
To: "'William Lupton'" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 8 Apr 1999 12:38:03 -0600
On Wednesday, April 07, 1999 2:39 PM, William Lupton [SMTP:[email protected]] wrote:
> looking for an existing entry point. On the Power PC, it doesn't find the
> first two but does find the last. I think (Jeff Hill might care to comment)
> that it would be fine simply not to search for the first two on the Power PC.
Not searching for the first two on this board, or not printing the message,
would I suspect not prevent devLib.c from concluding on this architecture
that drivers are replacing an
operational interrupt service routine when in fact a default (unsolicited)
interrupt service stub is being replaced. I dont care to imagine the
rationale for changing the name of the stubs on this particular board.
So we need to know the names of the unsolicited interrupt vector handlers for
this board, or we need to come up with an architecture neutral method to determine
what the address of these subroutines is.
It _is_ odd that this problem was not seen on other PPC boards?
Jeff
Prev: RE: problems with OMS motor controller and power pc cpu board mv2306 Jeff Hill
Next: RE: problems with OMS motor controller and power pc cpu board mv2306 William Lupton
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
