On Wednesday, April 07, 1999 1:42 AM, Werner Portmann [SMTP:[email protected]] wrote:
> Hallo everybody
> I try to run an OMS motor controller with a mv2306 power pc cpu board
> and I don't
> succeed. During initialization I get the error message that _excStub and
> _excIntStub are not in the symbol table.
> With the mv167 board these two symbols are defined in vxWorks.
> In the case of the mv2306 these two symbols (and perhaps others, too)
> are not defined in vxWorks.
It appears that the list of the names of the default vxWorks interrupt
handler stubs in devLib.c, and probably also veclist.c need to be updated
for your architecture. It is possible that this message is unrelated to any
problems that may be occurring with the OMS card.
There is a list of names as follows in the code which appear now to be
architecture specific. We will perhaps need to add architecture specific
ifdefs to the code. This code detects situations where two drivers attempt
to use the same interrupt vector. It does this by checking to see if one of
the default interrupt stubs is currently installed.
To determine the defaults initially I ran through the vector table and obtained the
name of the symbols attached to each vector.
LOCAL char *defaultHandlerNames[] = {
"_excStub",
"_excIntStub",
"_unsolicitedHandlerEPICS"};
I suppose that we could almost guess at the address of the defaults
by running through all of the vectors, and guessing that all functions
that are attached to greater than N vectors are default interrupt stubs?
Open to suggestions.
Jeff
Re: problems with OMS motor controller and power pc cpu board mv2306 William Lupton
RE: problems with OMS motor controller and power pc cpu board mv2306 Jeff Hill
<1999>
2025
2026
<1999>
2025
2026
