Subject: |
RE: CA @ the SSTF in St. Louis MO |
"Michael J. Feldhake" <[email protected]> |
Date: |
Fri, 30 Apr 99 17:21:25 EDT |
Jeff,
Thanks for the response. I have attached a text file which is the CA
C/C++ code that I am using. It is part of a larger application which does
include a DDE server to communicate with the 'In Touch View' application.
I don't believe this code will cause the Channel Access to recreate
channels every time - I thought the ca_search function performed a connect
and that I can ca_get as fast as I can afterwards (I control this using a
control variable DAQstat). Please comment.
Mike
**This message was created in BeyondMail. Please ignore the ATTRIBS.BND
attachment if you are not a BeyondMail user.
The following was included as an attachement. Please use UUDECODE
to retrieve it. The original file name was 'caclient.txt'.
begin 666 caclient.txt
M+RH@9F]L;&]W:6YG(&YE961E9"!W:&5N('5S:6YG($5:0T$@*B\-"@T*(VEN
M8VQU9&4@(G-T9&%F>"YH(@T*(VEN8VQU9&4@(DU+0T%01"YH(@T*#0IE>'1E
M<FX@(D,B('L-"B-I;F-L=61E(#QS=&1D968N:#X-"B-I;F-L=61E(#QS=&1L
M:6(N:#X-"B-I;F-L=61E(#QS=&1I;RYH/@T*(VEN8VQU9&4@/'-T<FEN9RYH
M/@T*#0HC:6YC;'5D92`B8V%D968N:"(-"GT-"@T*+RH-"B-I9F1E9B!?1$5"
M54<-"B-D969I;F4@;F5W($1%0E5'7TY%5PT*(W5N9&5F(%1(25-?1DE,10T*
M<W1A=&EC(&-H87(@5$A)4U]&24Q%6UT@/2!?7T9)3$5?7SL-"B-E;F1I9@T*
M*B\-"@T*+RH-"B`J("!4:&ES(&ES(&$@<V5C;VYD('-T<G5C='5R92!R97%U
M:7)E9"!T;R!O<&5R871E('1H92!C82!C;&EE;G0N#0H@*B`@=&AE(&EN9&5X
M(&9O;&QO=W,@=&AE($1!44=L;V)?271E;2!L:7-T+"!T:&ES(&UU<W0@8F4@
M82!S=&%T:6,@;&ES=`T*("H)=VAI8V@@<V%V97,@=&AE(&-A(&EN9F]R;6%T
M:6]N(&]F('1H92!S<&5C:69I8R!C:&%N;F5L#0H@*B\-"F-H:60);7EC:&ED
M6TU+0T%01%]-05A?251%35-=.PDO+R!#2$E$(&EN9F]R;6%T:6]N(&]F('1H
M92!C82!C:&%N;F5L#0H-"FEN="!T97-T7V1A=&$@/2`P.PT*#0II;G0@;6MC
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M("TQ*0T*"7L-"@D)9F]R("AI/3`[(&D@/"!-2T-!4$1?34%87TE414U3.R!I
M*RLI#0H)"0E$05%';&]B7TET96US6VE=+GIZ4')O8U9A<B`](#`[#0H)?0T*
M"2\O($%T=&%C:"!T;R!+:6YE=&EC<R!C<F%T92!U<VEN9R!#:&%N;F5L($%C
M8V5S<PT*"6EF("A$05%3=&%T(#T](#`I#0H)>PT*"0DO+R!);FET:6%L:7IE
M(&-A#0H)"5-%5D-(2RAC85]T87-K7VEN:71I86QI>F4H*2PB8V%?=&%S:U]I
M;FET:6%L:7IE(BD["0D-"@D)+R\@<V5T($UO;FET;W)S#0H)"69O<B`H:3TP
M+"!E<G)C;G0@/2`P.R!I(#P@34M#05!$7TU!6%])5$5-4R`F)B!E<G)C;G0@
M/#T@,CL@:2LK*0T*"0E[#0H)"0ES=')C<'DH;6]N7W-T<BP@(F-M;3HB*3L-
M"@D)"7-T<F-A="AM;VY?<W1R+"!$05%';&]B7TET96US6VE=+D-E;&PI.PD)
M"0D)"0T*"0D)+R\@5T%3("!E<G)O<B`](&5Z8V%3971-;VYI=&]R*&UO;E]S
M='(L(&5Z8V%$;W5B;&4I.PT*"0D)4T560TA+*&-A7W-E87)C:"AM;VY?<W1R
M+"8H;7EC:&ED6VE=*2DL(")C85]S96%R8V@@9F%I;'5R92(I.PT*#0H)"0EI
M9B`H97)R;W(@/B`P*0T*"0D)"65R<F-N="LK.PT*"0E]#0H)"2\O(%=A:70@
M9F]R(&-A('1O('!R;V-E<W,@<F5Q=65S=',-"@D)4T560TA+*&-A7W!E;F1?
M:6\H-2XP*2PB8V%?<&5N9%]I;R!F86EL=7)E(BD[#0H)"2\O($-O;7!L971E
M(&EF(&D@/2!-2T-!4$1?34%87TE414U3#0H)"6EF("AI(#T]($U+0T%01%]-
M05A?251%35,@)B8@97)R;W(@/3T@,"D-"@D)"41!45-T870@/2`Q.PT*"0EE
M;'-E#0H)"0E$05%3=&%T(#T@,CL-"@E]#0H)+R\@57!D871E('9A<FEA8FQE
M<PT*"6EF("A$05%3=&%T(#T](#$I#0H)>PT*"0ET:6UE("@F8F5F;W)E*3L-
M"@D)+R\@=7!D871E($UO;FET;W)S#0H)"69O<B`H:3TP+"!E<G)C;G0@/2`P
M.R!I(#P@34M#05!$7TU!6%])5$5-4R`F)B!E<G)C;G0@/#T@,CL@:2LK*0T*
M"0E[#0H)"0ES=')C<'DH;6]N7W-T<BP@(F-M;3HB*3L-"@D)"7-T<F-A="AM
M;VY?<W1R+"!$05%';&]B7TET96US6VE=+D-E;&PI.PD)"0D)"0T*"0D)+R\@
M5T%3("!E<G)O<B`](&5Z8V%'970H;6]N7W-T<BP@1$%11VQO8E])=&5M<UMI
M72YZ>E!R;V-687(L(#$L("9D*3L-"@D)"5-%5D-(2RAC85]G970H1$)27T1/
M54),12QM>6-H:61;:5TL*'9O:60@*BDF1$%11VQO8E])=&5M<UMI72YZ>E!R
M;V-687(I+")C85]G970@9F%I;'5R92(I.PT*"0D)#0H)"0EI9B`H97)R;W(@
M/B`P*0T*"0D)"65R<F-N="LK.PT*"0E]#0H)"2\O(%=A:70@9F]R(&-A('1O
M('!R;V-E<W,@<F5Q=65S=',-"@D)4T560TA+*&-A7W!E;F1?:6\H-2XP*2PB
M8V%?<&5N9%]I;R!F86EL=7)E(BD[#0H)"71I;64@*"9A9G1E<BD[#0H)?0T*
M"2\O($1E;&%Y('5N=&EL(&YE>'0@36]N:71O<@T*"6EF("A$05%3=&%T(#T]
M(#(I#0H)"41!441L>51M<BLK.PT*"6EF("A$05%3=&%T(#T](#(@)B8@1$%1
M1&QY5&UR(#X@,C`P,"D-"@E[#0H)"41!441L>51M<B`](#`["0D)+R\@4F5S
M970@=&EM97(-"@D)1$%14W1A="`](#`["0D)+R\@5')Y(&%G86EN('1O('-E
M="!-;VYI=&]R<PT*"7T-"@T*"7)E='5R;B`P.PT*?0T*#0H-"B\J8V%%>&%M
M<&QE+F,J+PT*#0HO*@E%6$%-4$Q%($-/1$4@4D5&15)%3D-%#0H-"B-I;F-L
M=61E(#QS=&1D968N:#X-"B-I;F-L=61E(#QS=&1L:6(N:#X-"B-I;F-L=61E
M(#QS=&1I;RYH/@T*(VEN8VQU9&4@/'-T<FEN9RYH/@T*#0HC:6YC;'5D92`B
M8V%D968N:"(-"@T*;6%I;BAI;G0@87)G8RQC:&%R("HJ87)G=BD-"GL-"B`@
M("!D;W5B;&4)9&%T83L-"B`@("!C:&ED"6UY8VAI9#L-"@T*("`@(&EF*&%R
M9V,@(3T@,BD@>PT*"69P<FEN=&8H<W1D97)R+")U<V%G93H@8V%%>&%M<&QE
M('!V;F%M95QN(BD[#0H)97AI="@Q*3L-"B`@("!]#0H@("`@4T560TA+*&-A
M7W1A<VM?:6YI=&EA;&EZ92@I+")C85]T87-K7VEN:71I86QI>F4B*3L-"B`@
M("!3159#2$LH8V%?<V5A<F-H*&%R9W9;,5TL)FUY8VAI9"DL(F-A7W-E87)C
M:"!F86EL=7)E(BD[#0H@("`@4T560TA+*&-A7W!E;F1?:6\H-2XP*2PB8V%?
M<&5N9%]I;R!F86EL=7)E(BD[#0H@("`@4T560TA+*&-A7V=E="A$0E)?1$]5
M0DQ%+&UY8VAI9"PH=F]I9"`J*29D871A*2PB8V%?9V5T(&9A:6QU<F4B*3L-
M"B`@("!3159#2$LH8V%?<&5N9%]I;R@U+C`I+")C85]P96YD7VEO(&9A:6QU
M<F4B*3L-"B`@("!P<FEN=&8H(B5S("5F7&XB+&%R9W9;,5TL9&%T82D[#0H@
4("`@<F5T=7)N*#`I.PT*?0T**B\[
end
Booting vxworks from an AFS account luchini
Re: Booting vxworks from an AFS account Alan K Biocca
<1999>
2025
2026
RE: CA @ the SSTF in St. Louis MO Jeff Hill
C++ development on IRIX hosts Peregrine McGehee
<1999>
2025
2026
