1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA @ the SSTF in St. Louis MO
Date: Fri, 30 Apr 1999 11:05:08 -0600
Michael,
I suspect that the application is creating a new channel each time that it fetches
data, and then not deleting the channel when it is no longer in use. To use EPICS
Channel Access efficiently you must create the channels needed during application
startup, and not each time that you fetch data. When your application is no longer
using a channel then it must be deleted so that there is room for new channels
to be created in the server. Note that installing a Channel Access event subscription
(a monitor) is more efficient than periodically polling the IOC.
Type "casr [interest level]" on the IOC to see how many channels are currently in
use by your application.
Note also that Kay Kasemir here at LANL has created an EPICS CA DDE server
which can be used to easily and efficiently interface Microsoft DDE aware applications
to the EPICS CA client library. I am guessing that the "in touch" viewer might be
DDE aware.
Jeff
On Friday, April 30, 1999 8:10 AM, Michael J. Feldhake [SMTP:[email protected]] wrote:
> Gentlemen,
> 	I am happy to inform you that there is another functional CA Client
> running at Boeing's Subsonic Testing facility in St. Louis.  Unfortunately,
> the functional part is short lived - after about 10-15 minutes, the CA
> Client Diagnostics receives messages from the Server that it is unable to
> 'Allocate Additional Memory' for cell.....(See Attached screen dump bitmap
> for the complete message).  The DAQ Crate must be re-booted before the
> Channel Access port will respond again - all other activity appears to
> remain active in the crate from other accessible nodes (i.e. UNIX Clients).
> 	Can you provide us some assistance on this issue.  I hope it's no more
> than an incompatible driver issue with the Client using the later libraries
> from EPICS and the DAQ using older ones ?
> Thanks,
> Mike
> **This message was created in BeyondMail. Please ignore the ATTRIBS.BND
> attachment if you are not a BeyondMail user.
> The following was included as an attachement.  Please use UUDECODE
> to retrieve it.  The original file name was 'casv0429.bmp'.
>  << File: casv0429.bmp >>
Prev: C++ development on IRIX hosts Peregrine McGehee
Next: Booting vxworks from an AFS account luchini
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA @ the SSTF in St. Louis MO Michael J. Feldhake
Next: RE: CA @ the SSTF in St. Louis MO Michael J. Feldhake
