1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MV167 serial port
Date: Mon, 10 May 1999 08:08:29 -1000
> From [email protected] Mon May 10 06:01:58 1999
> Date: Mon, 10 May 1999 09:49:38 -0600
> Organization: LANL>
> On Monday, May 10, 1999 10:13 AM, Philip Taylor [SMTP:[email protected]] wrote:
> > Is it possible to use the serial port(s) on an MV167 directly
> > from EPICS?
> Yes
> > I can see there's an EPICS driver called drvSerial
> > at Keck - is this, or something else, suitable?
> The drvSerial code uses the C STDIO library to communicate
> so it works with any serial device that has a vxWorks
> serial device driver. This code provides only queuing
> and framing services. Allen Honey at Keck has a driver which
> is layered on drvSerial which can be configured to communicate
> with serial devices that communicate over simple command line
> ASCII based protocols. There are also a number of drivers for
> specific devices which use drvSerial.
> Jeff
In regards to drvAscci, the main thing to keep in mind is that,
drvAscii assumes that the remote end will not send asynchronous data,
that is, all data is prompted for from records on the Epics side.
You can get the source and a toy database (which will work if you
loopback rx and tx on your serial port) at Keck.
ftp to ftp.keck.hawaii.edu login as anonymous
cd /pub/epics/drivers
cd /drvAscii
ls
        drvAscii.README
        drvAscii.c
        drvAscii.h
        drvAscii.sch
        devAscii.c
        drvAscii.dbd
You will need drvSerial, upon which drvAscii is layered.
drvSerial was written for Keck by Jeff Hill. You should contact
Jeff as I have an older version of drvSerial.
I'm happy to help if you have difficulties.
Allan
Prev: Re: gpib device Maren Purves
Next: 14 or 16 bit IO boards Garrett D. Rinehart
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MV167 serial port Philip Taylor
Next: EPICS Channel Access Michael J. Feldhake
