Subject: |
RE: Building EPICS on Linux |
"Hammonds, John" <[email protected]> |
Date: |
Wed, 9 Jun 1999 20:02:02 -0500 |
Geoff,
It seems from what you have said, that you are just trying to keep the Host
and target compiler straight. I have compiled a good deal of the EPICS Host
stuff on Linux but have not yet tried getting to the target stuff. From the
quick look that I just took, it seems that you are looking now to modify
some of the stuff in CONFIG.Vx. I am not quite sure how to get this all
working since I have never done work setting up the cross compiler. The
error message that you are getting seems familiar though. Have you executed
the appopriate scripts in the startup directory. (for bash you need to
execute (EPICS_TOP)/startup/Site.profile.) I would be somewhat interested
in seeing what you are doing with the cross compiler.
John Hammonds
IPNS
Argonne
> -----Original Message-----
> From: Geoff Savage [SMTP:[email protected]]
> Sent: Wednesday, June 09, 1999 3:53 PM
> To: tech-talk
> Subject: Building EPICS on Linux
> We are attempting to setup an EPICS build enviroment on a PC running
> Linux. I have run into two difficulties.
> 1. I had to add an extra -B<bin path> to GCC. This specifies the
> location of the cross assembler, as.
> 2. The build stops with an error.
> ***No rule to make target `../../bin/mv162/vxWorks', needed by
> `buildInstall'. Stop.
> Now the questions:
> We use gcc as for cross compiles and for host compiles. How do I keep
> the two separate with hacking the GCC command line?
> Is there a clean way to remove the error message about vxWorks? Do I
> have to modify the iocCore vxworks makefile?
> Thanks in advance.
> Geoff Savage
Building EPICS on Linux Geoff Savage
RE: Building EPICS on Linux William Lupton
<1999>
2025
2026
<1999>
2025
2026
