1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: XY240 interrupts
To: <[email protected]>
Cc: <[email protected]>, "Garrett D. Rinehart" <[email protected]>
Date: Mon, 28 Jun 1999 10:27:27 -0600
Liam,
You will also need to call either sysIntEnable(intLevel) or
devEnableInterruptLevel() to enable the VME interrupt level that your
board is using.
Jeff
> Are you sure you have the IACK daisy chain completed on the
> backplane? If the
> source of the interrupt isn't right next to the cpu, the chain
> can be open. Then
> the interrupts are not handled.
> Garrett Rinehart
> Intense Pulsed Neutron Source
> Argonne National Laboratory
> 9700 S. Cass Ave
> Argonne, IL  60439
> (630)252-6561
> > To: tech-talk <[email protected]>
> > Subject: XY240 interrupts
> > MIME-Version: 1.0
> > Hello
> > I am currently trying to write some interrupt support for an XYCOM xy240
> > I/O board.
> > I have used devConnectInterrupt and intConnect to try and connect my ISR
> > with the interrupt from this board, to no avail.
> > When I input a signal to one of the interrupt inputs on the board, the
> > internal registers change properly, but my ISR does not run.
> > I suspect that either the board is not generating an interrupt,
> or that it
> > is being ignored somehow.
> > If anyone has any suggestions I would love to hear them.
> > Thanks
> > Liam O Neill
Re: XY240 interrupts Garrett D. Rinehart
Prev: Re: pp_value in dbd file Andrew Johnson
Next: Re: EPICS Record Reference Manual Steve Lewis
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: XY240 interrupts Garrett D. Rinehart
Next: Latest EPICS Documentation Leonard J. Reder
