1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS archiver
To: [email protected]
Cc: [email protected]
Date: Wed, 30 Jun 1999 16:52:28 -0400
> here another question. I am trying to use the archiver for EPICS, but
> there are several problems
> If I am using the snapshot mode, it could miss some things happened in
> between. If I use the monitor mode, it crashed when it reaches the file
> size that I specified.
It doesn't crash, it aborts intentionally (due to failure of an "assert()"
test on the success of a write to the file).
Not very friendly behavior, especially if you have more than one request
open, as it won't properly flush and close the others before exiting.
> And it gets tothat file size too fast. $ variables only take 3 hours to
> reach 1Mbytes.
The maximum file size allowed by AR seems to be 100 Mbytes.  This is set in
the OUTPUT line in the request file.
Also, look carefully at the data you are archiving.  It may be possible to
reduce the data rate by increasing deadbands (.ADEL) or using smoothing in
your database.
Brian McAllister                 Application Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
Re: EPICS archiver Eugene T. Yamamoto
EPICS archiver jlin
Prev: EPICS archiver jlin
Next: EPICS training Bob Dalesio
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS archiver Eugene T. Yamamoto
