1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: String PVs and the Portable CA Server.
To: [email protected]
Cc: [email protected]
Date: Wed, 21 Jul 1999 10:15:49 -0700 (PDT)
Hi Brian -
>I can declare a PV as type aitEnumString of length 1 and my defined
>callback routine will get the proper "Put" string, however, I can not
>get the "Scan" method to take a string from my process and display it in
>the served PV.  This would be handy for reporting error strings, for
>instance.
In my PCAS, I use only aitEnumFixedString (and make sure I allocate enough
room even if I don't need it) which works fine.  Luckily, most strings in
my application are 40 chars or less - the few oddball strings that are more,
I convert to unsigned byte arrays and let clients deal with them special
if they care (nobody's tried to connect to these few channels so nobody's
complained).
I'll be interested to know if you get aitEnumString to work.  Thanks,
Stephanie Allison
Re: String PVs and the Portable CA Server. Brian Tieman
Prev: RE: channel access time response Jeff Hill
Next: Re: String PVs and the Portable CA Server. john sinclair
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: String PVs and the Portable CA Server. john sinclair
Next: Re: String PVs and the Portable CA Server. Brian Tieman
