On Wed, 21 Jul 1999, Brian Tieman wrote:
> Hey all,
> Hopefully there's someone out there who can help me. We've been using
> the portable CA Server on Windows for close to a year now for several
> projects. What I did was to take the simple example program and modify
> it so it had the hooks we needed to serve PVs from code we wrote to
> control CCD cameras. The one bit of functionality I have yet to be able
> to get working is the proper serving of string PVs.
> I can declare a PV as type aitEnumString of length 1 and my defined
> callback routine will get the proper "Put" string, however, I can not
> get the "Scan" method to take a string from my process and display it in
> the served PV. This would be handy for reporting error strings, for
> instance.
> Below is the scan method for a scalar pv declared as aitFloat32.
> PVtypes is a union of all supported pvtypes. newValue is the value from
> my process which is to be "scanned" into the server and made availiable
> to client through caget calls.
> void exScalarPV::scanFloat32 (PVtypes *newValue)
> caStatus status;
> smartGDDPointer pDD;
> aitFloat32 limit;
> int gddStatus;
> pDD = new gddScalar (gddAppType_value, aitEnumFloat32);
> if (pDD==NULL) {
> return;
> // smart pointer class manages reference count after this point
> gddStatus = pDD->unreference();
> assert (!gddStatus);
> if (newValue != NULL)
> limit = (aitFloat32) this->info.getHopr();
> newValue->pvfloat32 = tsMin (newValue->pvfloat32, limit);
> limit = (aitFloat32) this->info.getLopr();
> newValue->pvfloat32 = tsMax (newValue->pvfloat32, limit);
> *pDD = newValue->pvfloat32;
> status = this->update (*pDD);
> if (status!=S_casApp_success)
> errMessage (status, "scalar scan update failed\n");
> This code works fine. When the PV is of type aitEnumString, however, I
> get the correct value in newValue as a char*, but I can't figure out how
> to properly scan that value into the smartGDDPointer so my clients can
> see it.
> If anyone has done this or knows how to do it, I'd much appreciate your
> help.
> Thanks!
> Brian Tieman
> APS
> [email protected]
I have used strings by declaring them as aitFixedString and using
no more that AIT_FIXED_STRING_SIZE characters.
I do, however, return aitEnumString from the bestExternalType function.
John Sinclair
[email protected]
Oak Ridge National Lab
423-576-6362 423-574-1268 (fax)
- String PVs and the Portable CA Server. Brian Tieman
Re: String PVs and the Portable CA Server. saa
RE: String PVs and the Portable CA Server. Peregrine McGehee
<1999>
2025
2026
<1999>
2025
2026
